chriskuku
Senior II
Jun 20, 2022 7:51 AM UTC
STM32CubeMX permission problem /Users under macOS 11.6.6.
I installed STM32CubeMX under macOS (11.6.6). When I click "about STM32CubMX" a box pops up:
java
Version 1.0 (11.0.10)
When I click "Generate code" I'm getting a box saying "/Users: permission denied"
SamHansen42
Sep 2, 2023 12:33 AM UTC
any luck? same issue
Visitor II
Dec 6, 2023 9:21 PM UTC
Ran into the exact same issue and was able to fix it by not using `/home` in the project location. macOS does not play well with `/home` so ensure you use `/Users/[YOUR USERNAME]` as the project location in the Project Manager tab.
Note you may have to start a new project as my existing project's path was greyed out after it attempted to generate code.
Visitor II
Aug 30, 2024 10:47 PM UTC
Ran into the same issue as well and it worked for me under ´/users/[YOUR USERNAME]/anotherdirectory`.
