STM32CubeMX inconsistent indentation for MX_TouchGFX_Process()
If I enable USB host and TouchGFX without OS I get the following generated code:
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    MX_USB_HOST_Process();
  MX_TouchGFX_Process();
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
As you can see MX_TouchGFX_Process() isn't indented properly.
I want this:
  while (1)
Kudo posts if you have the same problem and kudo replies if the solution works.
Click "Accept as Solution" if a reply solved your problem. If no solution was posted please answer with your own.
3 REPLIES 3
Souhaib MAZHOUD
Hello @unsigned_char_array
Could you share the project or the name of the MCU that occur this issue ?
Souhaib
STM32H735
I've attached an ioc file to reproduce the problem. I just created a fresh project for the STM32H735G-DK
with everything set to default and enabled TouchGFX and USB host.
Result:
  while (1)
Edit: still not fixed in STM32CubeMX V6.12.1
