2020-06-15 03:11 PM
I get the error message below twice when I try to create a new project on STM32CubeMX:
I tried deleting the crdb.zip file as mentioned in the post below: https://community.st.com/s/question/0D50X0000BBonsLSQR/stm32-cube-mx-error-downloading-the-following-files-crdbzip-cannot-unzipped
and performing a refresh but I still get the error message above.
Will there be any issues with my build if I ignore the message?
I also noticed that I could not perform any updates as pressing "Check For Updates" on the main window gives me the following error message:
Are there any workarounds to these problems? I tried uninstalling and re-installing STM32CubeMX but the error messages still appear. I am currently running STM32CubeMX 5.6.1.
Any help would be appreciated. Thanks!
2021-04-22 04:39 PM
I have the same problem here with CubeIDE!
Is there any solutions?
Best regards,
Amine
2021-04-22 08:41 PM
Hello, I too am having that exact same problem. I am using Version: STm32CubeIDE 1.6.1
Build: 9958_20210326_1446 (UTC). Once a new project is started, the system begins to download updates and other files from ST. Then at some point an error is generated: "Error downloading... crdb.zip (not available)" I've tried deleting the instances of crdb.zip in the computer, restarting, etc... But it still generates an error. Is someone working on a fix? The direct download link listed earlier (10 months ago) is now a "page not found".
2021-04-22 11:41 PM
I have the same problem, too. I reinstalled the CUBE IDE. I even tried to switch from 1.6.1 to 1.6.0 but the error still occurs. Would be great if someone who knows a fix could submit it here.
2021-04-23 06:28 AM
The problem is resolved here!
I have done nothing! I just rebooted my laptop. Then, everything goes well.
It seems that it was a server bug!
Good luck mates.
2021-04-23 06:48 AM
Same for me :) Thx.
2021-06-04 12:38 AM
Above setting solved my problem
2021-10-04 02:36 PM
I had the same issue. I downloaded the file of RrW and extracted it manually and restarted stm32CubeIDE. Then it worked!
Best Regards,
Bastien
