STM32CubeMX Code Generation for STM32CubeIDE without linking library files
BSpoe.1
why it's not possible to copy all neccessary library files to my generated project for CubeIDE?
When I choose EWARM, then this is possible...
Thanks a lot,
Ben
Khouloud ZEMMELI
​Hello @Community member​ ,
You need to Uncheck the "Generate Under Root" first then you will have access to all options.
Best Regards,
Khouloud
Khouloud ZEMMELI
Best Regards,
Khouloud
BSpoe.1
Thanks, this works!
Khouloud ZEMMELI
(Only the "Copy all used.." ​is grayed in your case, if you have a problem in other options thanks for telling me).
