STM32CubeMX Clock Configuration not generating any code for LSCO Source Mux
PCast.2
When selecting LSI as output for LSCO pin, and generating code with integrated STM32CubeMX, no output is seen on LSCO pin.
0693W00000FBt0wQAD.pngI have to manually add a call to this to see LSI on LSCO pin.
HAL_RCCEx_EnableLSCO(RCC_LSCOSOURCE_LSI);
When using MCO pin instead of LSCO pin, the code for source clock selection is generated correctly.
I'm using STM32CubeIDE v1.7.0. and STM32L432KCU MCU.
Thanks and kind regards,
Pedro.
Sara BEN HADJ YAHYA
Hello @PCast.2​ ,
This issue is fixed in the latest release of STM32CubeMX ( version 6.4.0 available on https://www.st.com/en/development-tools/stm32cubemx.html).
Thanks for your contribution.
When your question is answered, please close this topic by choosing Select as Best.
Sara.
7 REPLIES 7
Sara BEN HADJ YAHYA
Which STM32CubeMX version are you using?
Best Regards,
Sara
PCast.2
Hi Sara,
This is the info about STM32CubeMx version I found in .ioc file:
MxCube.Version=6.3.0
MxDb.Version=DB.6.0.30
ProjectManager.FirmwarePackage=STM32Cube FW_L4 V1.17.0
Best regards,
Pedro.
Sara BEN HADJ YAHYA
Hello again,
Could you please share with us your .ioc file?
Thanks in advance,
Sara.
PCast.2
Hello Sara,
Attached to this post you can find it.
Pedro.
Sara BEN HADJ YAHYA
Hi @PCast.2​ ,
Thanks for your feedback,
You are right, It seems that the STM32CubeMX does not generate the code to enable LSCO output, for now you have to add HAL_RCCEx_EnableLSCO(RCC_LSCOSOURCE_LSI); manually.
Your request have been reported internally, I'll keep you posted with the updates.
Sara.
PCast.2
Thank you Sara!
Sara BEN HADJ YAHYA
Hello @PCast.2​ ,
Sara.
