STM32CubeMX 5.6.0 doesn't generate LwIP IP Address Settings
thomasguenzel
I'm using STM32CubeMX to create a project for a NUCLEO-F746ZG with the LwIP middleware.
Unfortunately, the IP Address Settings (IP, Netmask, Gateway) don't show up in the code anymore. In MX_LWIP_Init() there's just
void MX_LWIP_Init(void) {
	/* IP addresses initialization */
	/* Initilialize the LwIP stack without RTOS */
	lwip_init();
without the actual address settings.
Before updating CubeMX the settings where done in between those two comments like this:
	IP_ADDRESS[0] = 192;
	IP_ADDRESS[1] = 168;
	IP_ADDRESS[2] = 0;
	IP_ADDRESS[3] = 2;
	NETMASK_ADDRESS[0] = 255;
	NETMASK_ADDRESS[1] = 255;
	NETMASK_ADDRESS[2] = 255;
	NETMASK_ADDRESS[3] = 0;
	GATEWAY_ADDRESS[0] = 0;
	GATEWAY_ADDRESS[1] = 0;
	GATEWAY_ADDRESS[2] = 0;
	GATEWAY_ADDRESS[3] = 0;
	lwip_init();
I can't seem to find them anywhere else (they only show up in the .ioc file).
Am I missing something or is this a bug in CubeMX?
I'm using CubeMX 5.6.0 and the STM32F7 MCU package 1.16.0.
Thanks,
Thomas
Khouloud ZEMMELI
​Hello @Thomas Günzel​
Thanks for your feedback , the fix will be available in the next CubeMX release
Best Regards,
Khouloud
4 REPLIES 4
Khouloud ZEMMELI
Best Regards,
Khouloud
PTiha
Senior
In the afternoon I tried the latest CubeMX (5.6.1). The problem is the same: the IP address settings are missing in the generated code.
Hello @PTiha​ ,
The fix will be available for the 6.0.0 MX version. The 5.6.1 is an exception version for the most critical bugs.
Best regards,
Khouloud
Thanks for the information!
When is the next big version (maybe 6.0) expected?
Best regards,
Peter
