STM32 CubeMX 6.0.0 resets clock configuration to 64MHz and other bad things
CDyer
STM32 CubeMX 6.0.0 resets clock configuration to 64MHz. I had to go back and fix everything by hand. Also, after generating code, there are several instances where HAL typedefs can't be found and it breaks FreeRTOS
I am in the process of going back to 5.6.1. Thank god for git
I recommend that no one updates to 6.0.0
Khouloud ZEMMELI
Hello @CDyer​
Could you please share the original ioc (with 5.6.1 version), to check your problem ? (We are deeply sorry for any inconvenience this may have caused)
Rq: FreeRtos issue will be fixed soon.
Thanks,
Khouloud
