Since the usb stack generated by CubeMX is not Hub compliant, I want to use tinyUSB. Are there any experiences with this stack? The migration with the current version seems not straight forward.
MHerr.8
mohamed.ayed
Hi @MHerr.8​ i recommande to use AzureRtos USBX stack which support Hub class driver, you can take a look to this Ux_Host_HUB_HID_MSC application with STM32U5x9J-DK;
https://github.com/STMicroelectronics/STM32CubeU5/tree/main/Projects/STM32U5x9J-DK/Applications/USBX/Ux_Host_HUB_HID_MSC
3 REPLIES 3
Haithem Rahmani
Hi @MHerr.8​,
welcome to our community 😊.
Could you please provide more details on which STM32 are you working?
thanks & regards
Haithem.
MHerr.8
yes of course. I work on an STM32H753IIT6 on a self designed board. The software components are taken from CubeMX (freertos, USB Drivers and so on). Also the usb stack was taken from there until I found out, that this stack does not support Hubs. The external Hub is a tusb4020 from TI.
Thanks a lot.
Best regards
Martin
mohamed.ayed
