Problems related with NetXDuo
‎2025-04-16 2:19 AM
Hello everyone,
I'd like to report some issues I encountered while using NetXDuo to create a UDP server with a Nucleo-N657X0-Q board:
- There's no option to select a network interface other than the custom one — I had to manually add all the libraries related to the Ethernet interface and the LAN8742 driver.
- The folder ../../Drivers/CMSIS/Device/ST/STM32N6xx/Include/Templates needs to be added manually.
- Enabling NX_ENABLE_VLAN has no effect in the nx_user.h file.
- The linker script STM32N657X0HXQ_AXISRAM2_fsbl.ld is missing the tcp_sec and nx_data sections.
After addressing all the issues above, I was finally able to get the UDP server working correctly!
- Labels:
Bug-report
‎2025-04-21 9:04 AM
Hello @LisaB
After check I confirm the issue and an internal ticket 208214 has been submitted to the dedicated team for fix.
For the 4th point, the tcp_sec and nx_data sections are not missing, but they need to be added manually as mentioned in this thread.
BR,
Souhaib
‎2025-04-16 2:29 AM
Hello @LisaB
Thank you for your contribution.
This issue is currently under investigation. I will get back to you as soon as possible.
BR,
Souhaib
‎2025-04-18 3:40 AM
Hello @LisaB
Can you include your IOC so that we can further investigate the issue?
‎2025-04-18 7:55 AM
Hello @Souhaib MAZHOUD,
sure, attacched the ioc file.
I configured in Stm32CubeIDE the UDP server as shown in the esample provided with the firmware STM32N6.
‎2025-04-21 9:04 AM
Hello @LisaB
BR,
Souhaib
