2020-05-26 11:54 PM
I am using STM32F103C8Tx and I am trying to create a PID adjustable PWM. In PID I will be giving values to PWM from 0 to 100 to set the duty cycle. That means my counter period needs to be 100 in Cubemx. Because as I have learnt while I am changing the dutch cycle it changes the counter period. However, I need to create PWM with 200 KHz frequency and the clock of the timer is 72 MHz.In order to achieve a value of 100 in counter period I need to have a 3.6 prescaler. Am I following a wrong way or did I get this PWM duty cycle thing wrong in stm32?
Note: I am changing duty cycle from the code as
htimx.Instance->CCRx =Duty_Cycle;I think I cannot put codes as a reply so I will put them here:
static void MX_TIM3_Init(void)
/* USER CODE BEGIN TIM3_Init 0 */
/* USER CODE END TIM3_Init 0 */
TIM_MasterConfigTypeDef sMasterConfig = {0};
TIM_OC_InitTypeDef sConfigOC = {0};
/* USER CODE BEGIN TIM3_Init 1 */
/* USER CODE END TIM3_Init 1 */
htim3.Instance = TIM3;
htim3.Init.Prescaler = 1;
htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
htim3.Init.Period = 359;
htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_PWM_Init(&htim3) != HAL_OK)
Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
Error_Handler();
sConfigOC.OCMode = TIM_OCMODE_PWM1;
sConfigOC.Pulse = 0;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
Error_Handler();
if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM3_Init 2 */
/* USER CODE END TIM3_Init 2 */
HAL_TIM_MspPostInit(&htim3);
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
/** Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
Error_Handler();
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC|RCC_PERIPHCLK_USB;
PeriphClkInit.AdcClockSelection = RCC_ADCPCLK2_DIV6;
PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL_DIV1_5;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
2020-05-27 5:11 AM
I look it with oscillscope. here is the view:
2020-05-27 5:13 AM
I don't know how to check them... You mean these?
geçe
htim3.Init.Prescaler = 1-1;
htim3.Init.Period = 360-1;
2020-05-27 5:17 AM
You mean these? :
geçe
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
2020-05-27 5:18 AM
You mean these?
Error_Handler();
Error_Handler();
Error_Handler();
geçe
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
2020-05-27 5:20 AM
I am not sure if I put the correct ones. I added codes to the main question
2020-05-27 5:31 AM
I added to the main question. I am not sure if they are the correct ones though
2020-05-27 5:57 AM
I played with prescaler and counter period values. When I tried with higher counter period such as 20000 etc. It gives correct frequency. But when I decrease counter period to 360. It starts to give wrong and higher frequencies. Might be the cause because of the capability of the MCU? Maybe it cannot produce PWM with that high frequency? (200 kHz)
PS: When I use prescaler:1 and counter period:199. Now it works. I guess we cannot use 0 in the prescaler..
2020-05-27 9:33 AM
Give numbers.
How exactly do you measure it?
Yes we can.
