Nucleo-144 STM32F767. Example USB-MSC-Device doesn't connect to PC correctly.
NikDobro
Hi, colleges!
I use Nucleo-144 STm32F767 development board to learn USB.
Now - Application example - device USB MSC.
The example uses SD card, with I haven't. I want to use internal instead of SD card. So, I changed the "usbd_storage.c" file. Plugged and not played =) Error - Cann't start this device (code 10).
My STM32 is falling in HardFault_Handler. I've put break point in "Handle Enumeration done Interrupt" and seen the process has stopped. The enumeration process is done. Ok.
What is going then? Which step is next? Where I need to put my break point?
I don't really know how to debug USB transaction and communication process. Wireshark doesn't see my device at all.
uint8_t usbMassStorage[0x1000];
int8_t STORAGE_GetCapacity(uint8_t lun, uint32_t *block_num, uint16_t *block_size)
  *block_num = sizeof(usbMassStorage)/512;
  *block_size = 512;
  return 0;
int8_t STORAGE_IsReady(uint8_t lun)
  return 0;
int8_t STORAGE_IsWriteProtected(uint8_t lun)
  return 0;
int8_t STORAGE_Read(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len)
  memcpy(buf,&usbMassStorage[blk_addr],blk_len);
  return 0;
int8_t STORAGE_Write(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len)
  memcpy(&usbMassStorage[blk_addr],buf,blk_len);
  return 0;
int8_t STORAGE_GetMaxLun(void)
  return(STORAGE_LUN_NBR - 1);
NikDobro
One problem is solve. The PC detects my STM32 MCU as MSC.
I've just changed string descriptors index to 0x00 in device descriptor.
How can I write or read smth to/from my MCU? Why it shows 0 kb memory disk?
3 REPLIES 3
NikDobro
Pavel A.
Evangelist III
Because 0x1000 is 4K bytes. 8 blocks. Too small to create any decent filesystem.
-- pa
I'm not sure. I tried with concrete values.
  *block_num = 0x100;
  *block_size = 0x20;
It gave the same result. But MS OS suggested me to format disk. In the window I saw 8 kb. But then was error in format disk process.
