2016-02-04 02:25 AM
Hi all,
Quite new in the development with LWIP, there is a question I have not found any answer so far; What is the minimum / maximuum frequency at which the main LWIP process function shall be called? I'm talking about the one generated by CubeMX: MX_LWIP_Process. We don't run it as seen in examples, that is in a simple while(1) loop in the main program. We want (and need) to use it from an IT. Thank you for your help #lwip-process-cubemx2016-02-08 10:33 PM
