Keil Project file have generation problem.
Proteus
Im currently using last verison of CUBEMX , when I creating project keil project file have been generation problem.
I re-installed program,Changed path of CUBEMX as C/: as well as shorth pathway with english characters.
Thanks A lot
4 REPLIES 4
Khouloud ZEMMELI
​Hello @Proteus​
Could you please give me more details? the path of the project or the CubeMX contains a french characters (like é ç .. ) ?
When you have changed the pathway with english characters the problem has been solved ?
And Please can you  share your ioc project if the problem is in the project generated  whatever the path ?
Thanks,
Khouloud
Proteus
Problem has never been solved. I tried with just english characters in C/:example/ like this source code succesfully generated but keıl project fıle have the problem.By the way when compiling for IAR ı couldnt see any problem
Proteus
I found , the problem is java version ı have been using java 13 version.I turned to Java 8 version.Now it's ok.
I think there is the bug
Thanks for everything
​Great,
Khouloud.
