i generate code using cube. i use freertos andtimer interrupt. the timer interrupt is not work i dont know whay. i open example project and copy my timer hardware configuration to the project and is work ok. advice thanks
ATvit
Perhaps look critically at the interrupt loading and task switching you are causing.​
