how to deal with this error?
error downloading the following files: crdb_full.zip
‎2023-05-06 1:52 AM - edited ‎2023-11-20 6:15 AM
I get this error in downloading files in side stm32cubemx:
STM32CubeMX
‎2023-05-08 12:02 AM
Hello @MJavi.1​ ,
Did you trying using CubeMX with admin right?
Please have a look at this post, it may help you.
If you still have issues, don't hesitate to come back with update.
When your question is answered, please close this topic by choosing Select as Best.
Imen
Imen
‎2024-06-15 2:17 AM
Sorry, I am running as an administrator in version 6.11.1 of STM32CubeMX, and in Start My Project from MCU
This error still occurs when ACCESS TOMCU SELECT
‎2025-02-18 6:48 AM
Hello!
I think you have fixed the problem by now. But maybe someone who has the same problem will be interested.
I had a similar problem when I tried to install the SMT32G474 package.
After I moved the folder for the firmware repository from my user directory to a general directory on the C disk, the problem no longer occurred.
You can find the settings under: [Help/Connection & Updates] and the [Updater Settings] tab in the dialog.
In the [Firmware Repository] section, I set the directory to
C:\Local\Tools\STMicroelectronics\STM32Cube\Repository
But all other generally accessible directories without spaces(?) should work.
It was then possible to install the packages.
With kind regards,
Timo
