How to config the OTFDEC with CubeMX?
V.H
I used STM32H730IB but I cannot config the OTFDEC.
"Warning: This peripheral has no parameters to be configured." when I activated the OTFDEC.
Sara BEN HADJ YAHYA
Hello @V.H​ ,
Thanks for your feedback,
Actually the OTFDEC doesn't have any parameter to configure.
Please check the AN5281 titled "How to use OTFDEC for encryption/decryption in trusted environment on STM32H7Bxxx and STM32H73xx microcontrollers".
I also advise you to check the examples in Example Selector, there are several examples for OTFDEC that might help you.
If you issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Sara.
Sara BEN HADJ YAHYA
Hello @V.H​ ,
Sara.
