2026-04-08 2:40 AM - last edited on 2026-04-08 2:53 AM by Andrew Neil
Moved to CubeMX forum as this is about the CubeMX functionality - even though it's within CubeIDE.
hello everyone. I'm trying to code my H7 chip. In the .ioc shen I try to generate code I take this error.
(I'm using CubeIDE 1.19.0)
then I turn back and look at my Clock configuration, only this HSI button has a issue.
and ı dont know how to fix this and is there any problem with the HSI usage.
also the other of all the clock config is :
I couldtn find same problem in the forum. or a solution.
2026-04-08 2:51 AM
Hello @BedirhanY
Actually this is not an error, it's just a warning, can you add your ioc to investigate further the behavior.
BR, Souhaib
