How to clear a MX specification for a timer channel
JBonn
Go into the timer and set the channel to Disabled. Or click the pin and set it to Reset_State.
JBonn
Thanks for your answer. Channel 1 does not give a "Disable" option. The other channels do.
What pin is Timer 3 Channel 1on? I did not assign it a pin.
The "Reset Configuration" resets the configuration info but the channel 1 setting
Your question is lacking sufficient detail. Include the chip you're working with. Include a screenshot if necessary.
