2021-09-12 05:13 AM
How can I add a custom board, by a different manufacturer, to use in STM32CubeMX
Any help appreciated
2021-09-12 07:04 AM
You can't add a board that can be selected in the "Board Selector," but you can select the chip used, and then configure the pins as they are used on the board.
2021-09-12 07:04 AM
