HAL_I2C_Master_Transmit always returns != HAL_OK
STai.2
I am using STM32 Cube MX to generate 32L443RCTx code.
In function HAL_I2C_Master_Transmit always returns != HAL_OK
Any ideas why?
waclawek.jan
There's a NAK at the end, i.e. the slave does not answer (it's not present, not connected, not working...)
4 REPLIES 4
waclawek.jan
And what is on SDA/SCL when observed using oscilloscope/LA?
STai.2
Only reply 0x90
SDA/SCL As attached file
waclawek.jan
STai.2
Working
Thanks!​
