2020-03-30 11:38 PM
I tried to generate a simple LL code CubeMX for NUCLEO - H745ZI. I cleared all pinouts, made PB0 as GPIO output, assigned context M7 to GPIO, change clock to HSI from HSE and generate code.
Observation: They are still so many functions used in main.c and corresponding files not included, hence the code doesn't build.
Has anyone generated pure LL code using CubeMX ?
Thank You.
2020-03-31 8:42 AM
Hello @sarojj7 ,
Could you please share the result of build and your ioc file to more check the issue ?
Thanks,
Khouloud
2020-04-01 4:09 AM
Issue confirmed, it will be fixed.
Thanks for your feedback.
Khouloud
