Ismo Manninen
Visitor II
March 22, 2017
CubeMX v4.20.0 bug in clock configuration?
  • March 22, 2017
  • 893 views
Posted on March 22, 2017 at 23:04
When I generate code for STM32L151CBTx (FW v1.6.0) using CubeMX it enables MCI clock (RCC_ORCILLATORTYPE_MSI) in SystemClock_Config even if only HSI is enabled in the CubeMX clock configuration UI. Similar problem does not exist for other chip versions e.g. L152CBTx.
This misconfiguration causes HAL_RCC_OscConfig to fail.
#cubemx-bug
Best answer by Sirma Siang
Posted on April 28, 2017 at 11:08
Hello
ismoman
I would like to thank you for your bug report.
I tested with CubeMX4.1 and this issue cannot be reproduced.
This version correct a clock configuratin regression that has passed through all our validation tests.
I recommend you to update your CubeMX to the 4.1 version.
Kind regards
Sirma
Posted on March 23, 2017 at 11:31
I confirm this bug which is already reported internally to our CubeMx team and will be fixed soon in the new patch release.
Sorry for the inconvenience it may bring.
Imen
Sirma Siang
Sirma SiangBest answer
Hello
ismoman
Kind regards
Sirma
