CubeMX set files in read only mode on each generation
ANauz.1
Senior II
I'm working with STM32CubeMX version 6.9.2
Each time I generate, all files in Drivers and in Middlewares\Third_Party\FreeRTOS directory are set in read only mode. I can remove it, and each time read only mode is set again.
This is really annoying!
Seen when generating for L4 µC
Ghofrane GSOURI
Hello @ANauz.1
First let me thank you for posting.
Actually I couldn't reproduce the issue, could you please provide your IOC in order to push further the investigation.
Thx
Ghofrane
Here is the ioc file I'm using. I just tried in a new empty directory, and I still get the error. Files in Drivers directory are generated (and regenerated) in read only mode.
Antoine
Pavel A.
The Process Explorer can help you understand why a certain file is read-only: is it created in this mode by Cube or something else does it later.
