CubeMX Makefile Generator Reported Error while Updating Project
imi415
Posted on June 07, 2018 at 18:44
After updating to CubeMX 4.26.0, Makefile projects cannot be updated due to the following errors:
2018-06-08 00:35:55,360 [INFO] ToolchainGenerator:120 - stack trace : java.lang.UnsupportedOperationException: Not supported yet.
at generators.MakefileGenerator.updateHeapAndStack(MakefileGenerator.java:315)
at generators.Generator.generateLinkerFile(Generator.java:715)
at generators.Generator.copyLinkerFile(Generator.java:407)
at convertor.Convertor.generateMakefile(Convertor.java:1436)
at convertor.Convertor.generate(Convertor.java:608)
at convertor.Convertor.convert(Convertor.java:515)
at convertor.Convertor.updateProject(Convertor.java:384)
at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.update(ToolchainGenerator.java:114)
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createToolChainFolders(ProjectBuilder.java:1780)
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createProject(ProjectBuilder.java:574)
at com.st.microxplorer.plugins.projectmanager.engine.GenerateProjectThread.run(GenerateProjectThread.java:41)
#stm32cubemx.
11 REPLIES 11
Beni1
Having the same issue with version 4.26.1 here too, when regenerating a Makefile project. Any updates?
