Cant open ioc file anymore - Invalid Input: Must be project's active .ioc file. Project's 'mipcontrol' active one is 'mipcontrol.ioc' file
i can't no longer open my ioc file. In my case its name is MIPControl. My projectname is mipcontrol. I know to change the name of the problem should fix it. But in my .project file the name is already set to MIPControl.
When i rightclick on my project and rename it manually to MIPControl i can open the ioc file agin. BUT when i rename it the git repo will be deleted from egit und there is no git repo i can use (i use git in my konsole)
Does anyone know where the information is stored that the io file has to be ***.ioc?
2 REPLIES 2
Pavel A.
Evangelist III
Use the standalone CubeMX. It is free of silly nuisances of the CubeIDE plugin. Name your .ioc files as you want.
Really? You have not pushed the repo to a remote server (github)?
just the local repo ;-) I push every day after work but renaming the Project name cause complete delete of the local repo
