Can we please have an option in CubeMX for interfacing with fatfs over spi for microcontrollers that don't have a sdio interface? Alternatively has anybody out there written a user_diskio.c and user_diskio.h that i could use? thanks
Taylor Welsh
4 REPLIES 4
HAL Example using SPI attached SD Card using the common BSP abstraction
STM32Cube_FW_F7_V1.12.0\Drivers\BSP\Adafruit_Shield\stm32_adafruit_sd.c
STM32Cube_FW_F7_V1.12.0\Projects\STM32F722ZE-Nucleo\Applications\FatFS\FatFs_uSD\readme.txt
Taylor Welsh
what would I need to do in order to use this code with a project generated under CubeMX?
I guess you'd need to figure out how it uses BSP or user/template code in other circumstances, and then apply that to your board. Sorry I don't CubeMX
Taylor Welsh
For others stuck in this position i found kiwih's drivers very useful, it's an easy drop in implementation for existing CubeMX projects.
https://github.com/kiwih/cubemx-mmc-sd-card
