[BUG REPORT] Code generation messes up some UTF characters in user code sections
Kazimierz Król
I am using some UTF-8 characters in my code that shows messages to the user, and some of them get converted to some other code page when I regenerate the code. This happens when generating code both from CubeIDE ioc editor and CubeMX.
This is how my code looks before generation:
0693W00000Y7SuRQAV.pngAnd after generation:
The characters �?, Ę and Ń get messed up.
CubeIDE version: 1.11.0
CubeMX version: 6.7.0
Rim LANDOLSI
Hi Kazimierz Król ,
Thank you for your contributions and for your detailed explanations.
The issue has been reported to STM32CubeMX development team.
Internal ticket number: 142800 (This is an internal tracking number and is not accessible or usable by customers).
I will keep you posted with updates, and I hope that this answered your question.
Rim
Rim LANDOLSI
Hello Kazimierz Król,
Thank you for reporting this issue !
The C standard depends on the compiler and how it copes with the various character sets.
In gcc, you should be able to override the default (UTF-8) encoding using the -fexec-charset switch
Invocation (The C Preprocessor) (gnu.org)
You might be able to use ASCII or some of the charsets listed here libiconv - GNU Project - Free Software Foundation (FSF).
Rim
Thank you for the suggestions. I have already used other character encodings, but for this project I want to use UTF-8 specifically. CubeMX should not interfere with that.
Rim LANDOLSI
Hi Kazimierz Król ,
Rim
