after generate code in cube.mx i am getting DTCMRAM .__USE_heapstack__overflow by 29950 ,then i fix the error it's works fine , but I am geeting error in validation target in cube.mx ..
pls help me..
Options
2022-12-19 10:30 PM
1 REPLY 1
Options
2022-12-28 1:40 AM
Hi @jeman.1 ,
Could you please:
1- avoid writing the whole question in the title
2- precise the STM32 product you are using
3- provide more details on the issue: which MX version are you using? at which level exactly the error is faced? If at compilation level, which IDE are you using? how did you fixed the initial error? what do you mean by 'error in validation target'?
-Amel
