A lot of errors in STM32Cube_FW_F0_V1.11.0
‎2019-11-26 5:40 PM
Error 1:
MX version: STM32CubeMX 5.4.0
Firmware: STM32Cube_FW_F0_V1.11.0
Compiler: IAR
MCU: Any in F0 series
Compiling error:
Error[Pe147]: declaration is incompatible with "__interwork __softfp void assert_failed(uint8_t *, uint32_t)" (declared at line 308 of "… main.c�?
Analysis:
The function, assert_failed(), generated by STM32CubeMX in main.c is defined as follows:
void assert_failed(char *file, uint32_t line) {}
The protoypte of this function should be below as mentioned in Release notes:
void assert_failed(uint8_t *file, uint32_t line) {}
Error 2:
Compiler: IAR
MCU: STM32F042
Compiling error:
Error[Pe136]: “… stm32f0xx_hal_crc.h has no field "DefaultPolynomialUse�? “
Analysis:
On the one hand, the generating Polynomial in CRC peripheral of STM32F042 is not programmable, the macro CRC_POL_POL is undefined, as a result, DefaultPolynomialUse is not a member of struct CRC_InitTypeDef.
On the other hand, the code generated by STM342CubeMX has the statement with DefaultPolynomialUse as follows:
hcrc.Init.DefaultPolynomialUse = DEFAULT_POLYNOMIAL_ENABLE;
Error 3:
Compiler: IAR
MCU: STM32F072
Linker error:
Error[Li005]: no definition for "HAL_CRCEx_Init" [referenced from … crc.o]
Analysis:
The code in function MX_CRC_Init() generated by STM32CubMX has the statements below:
if (HAL_CRCEx_Init(&hcrc) != HAL_OK) …
As mentioned in Release notes, HAL_CRCEx_Init has been abandoned and undefined and should not be used.
Recommendations on STM32CubeMX:
R1: A specific channel or mailbox should be created or provided to make developers submitting bug report conveniently.
R2: The path where the STMCubMX Repository should be configurable by developers.
- Labels:
STM32CubeMX
‎2019-11-26 11:19 PM
​hello @TNaxi​ ,
Could you please share your iocs files for each error ?
Thanks,
Khouloud.
‎2019-11-27 12:13 AM
@TNaxi​ : Only error 2 is reproduced -> it will be fixed.
need your ioc file for error 1 and for error 3.
Thanks and Best Regards,
Khouloud
‎2019-11-27 5:53 PM
The attachment is the ioc file we used.
Tian Naxin
‎2019-11-27 6:53 PM
The path is already configurable.
What you probably want is to have two separate independent repository paths: A. for CubeMX itself to install & update its templates(?) etc. and B. the path to use in generated projects when user chooses to create references vs. copy files.
Like it was in older Cube versions.
-- pa
‎2019-11-27 11:04 PM
​@TNaxi​ I can not see any attachement.
‎2019-11-28 12:32 AM
#MicroXplorer Configuration settings - do not modify
CRC.CRCLength=CRC_POLYLENGTH_16B
CRC.DefaultInitValueUse=DEFAULT_INIT_VALUE_ENABLE
CRC.DefaultPolynomialUse=DEFAULT_POLYNOMIAL_DISABLE
CRC.IPParameters=DefaultPolynomialUse,DefaultInitValueUse,CRCLength
File.Version=6
KeepUserPlacement=false
Mcu.Family=STM32F0
Mcu.IP0=CRC
Mcu.IP1=NVIC
Mcu.IP2=RCC
Mcu.IP3=SYS
Mcu.IPNb=4
Mcu.Name=STM32F072R(8-B)Tx
Mcu.Package=LQFP64
Mcu.Pin0=VP_CRC_VS_CRC
Mcu.Pin1=VP_SYS_VS_Systick
Mcu.PinsNb=2
Mcu.ThirdPartyNb=0
Mcu.UserConstants=
Mcu.UserName=STM32F072RBTx
MxCube.Version=5.4.0
MxDb.Version=DB.5.0.40
NVIC.ForceEnableDMAVector=true
NVIC.HardFault_IRQn=true\:0\:0\:false\:false\:true\:false\:false
NVIC.NonMaskableInt_IRQn=true\:0\:0\:false\:false\:true\:false\:false
NVIC.PendSV_IRQn=true\:0\:0\:false\:false\:true\:false\:false
NVIC.SVC_IRQn=true\:0\:0\:false\:false\:true\:false\:false
NVIC.SysTick_IRQn=true\:0\:0\:false\:false\:true\:false\:true
PCC.Checker=false
PCC.Line=STM32F0x2
PCC.MCU=STM32F072R(8-B)Tx
PCC.PartNumber=STM32F072RBTx
PCC.Seq0=0
PCC.Series=STM32F0
PCC.Temperature=25
PCC.Vdd=3.6
PinOutPanel.RotationAngle=0
ProjectManager.AskForMigrate=true
ProjectManager.BackupPrevious=true
ProjectManager.CompilerOptimize=6
ProjectManager.ComputerToolchain=false
ProjectManager.CoupleFile=true
ProjectManager.CustomerFirmwarePackage=
ProjectManager.DefaultFWLocation=true
ProjectManager.DeletePrevious=false
ProjectManager.DeviceId=STM32F072RBTx
ProjectManager.FirmwarePackage=STM32Cube FW_F0 V1.11.0
ProjectManager.FreePins=false
ProjectManager.HalAssertFull=false
ProjectManager.HeapSize=0x20
ProjectManager.KeepUserCode=true
ProjectManager.LastFirmware=true
ProjectManager.LibraryCopy=2
ProjectManager.MainLocation=Src
ProjectManager.NoMain=false
ProjectManager.PreviousToolchain=
ProjectManager.ProjectBuild=false
ProjectManager.ProjectFileName=CuC.ioc
ProjectManager.ProjectName=CuC
ProjectManager.StackSize=0x400
ProjectManager.TargetToolchain=EWARM V8.32
ProjectManager.ToolChainLocation=
ProjectManager.UnderRoot=false
ProjectManager.functionlistsort=1-SystemClock_Config-RCC-false-HAL-false,2-MX_CRC_Init-CRC-false-HAL-true
RCC.CECFreq_Value=32786.88524590164
RCC.FamilyName=M
RCC.HSICECFreq_Value=32786.88524590164
RCC.IPParameters=CECFreq_Value,FamilyName,HSICECFreq_Value,PLLCLKFreq_Value,PLLMCOFreq_Value,TimSysFreq_Value,VCOOutput2Freq_Value
RCC.PLLCLKFreq_Value=16000000
RCC.PLLMCOFreq_Value=16000000
RCC.TimSysFreq_Value=8000000
RCC.VCOOutput2Freq_Value=8000000
VP_CRC_VS_CRC.Mode=CRC_Activate
VP_CRC_VS_CRC.Signal=CRC_VS_CRC
VP_SYS_VS_Systick.Mode=SysTick
VP_SYS_VS_Systick.Signal=SYS_VS_Systick
board=custom
‎2019-11-28 1:06 AM
I am facing issues in the CAN section of the STM32Cube_FW_F0_V1.11.0.
My .ioc file is attached for your reference.
The HAL_CAN_AddTxMsg(..args..) goes to Hardfault Handler at the line:
/* Store the Tx mailbox */
*pTxMailbox = (uint32_t)1 << transmitmailbox;
I wrote a simple snippet for CAN Transmit as:
void TransmitCAN(uint32_t StdID, uint8_t *data_arr, uint8_t DLC)
CAN_TxHeaderTypeDef TxMsg = {0};
TxMsg.StdId = StdID;
TxMsg.IDE = CAN_ID_STD;
TxMsg.RTR = CAN_RTR_DATA;
TxMsg.DLC = DLC;
TxMsg.TransmitGlobalTime = DISABLE;
HAL_CAN_AddTxMessage(&hcan, &TxMsg, data_arr, (uint32_t*)CAN_TX_MAILBOX0);
if((hcan.Instance->TSR & CAN_TSR_TXOK0) != RESET)
if((hcan.Instance->TSR & CAN_TSR_TXOK1) != RESET)
if((hcan.Instance->TSR & CAN_TSR_TXOK2) != RESET)
Error_Handler();
I called the same in a while(1) loop in main.c…
The same code works for F4 or F3 series controllers. Also the code I had written for CAN using the V1.9 for the same board works. So I have eliminated Hardware issues at my end.
‎2019-11-28 1:37 AM
​Ok Thanks for the share, for the 3rd problem it's reproduced now,
And it will be fixed too.
Still the 1er error, need your ioc file , just copy the content of our ioc file as you have already did .
Best Regards,
Khouloud.
‎2019-11-28 3:08 AM
File.Version=6
Mcu.Family=STM32F0
Mcu.IP0=NVIC
Mcu.IP1=RCC
Mcu.IP2=SYS
Mcu.IPNb=3
Mcu.Name=STM32F042K(4-6)Tx
Mcu.Package=LQFP32
Mcu.Pin0=VP_SYS_VS_Systick
Mcu.PinsNb=1
Mcu.ThirdPartyNb=0
Mcu.UserConstants=
Mcu.UserName=STM32F042K6Tx
PCC.Checker=false
PCC.Line=STM32F0x2
PCC.MCU=STM32F042K(4-6)Tx
PCC.PartNumber=STM32F042K6Tx
PCC.Seq0=0
PCC.Series=STM32F0
PCC.Temperature=25
PCC.Vdd=3.6
ProjectManager.DeviceId=STM32F042K6Tx
ProjectManager.HalAssertFull=true
ProjectManager.ProjectFileName=DuD.ioc
ProjectManager.ProjectName=DuD
RCC.FamilyName=M
board=custom
------------------ 原始邮件 ------------------
�?�件人: "ST Community"
收件人: "神散形�?散"<673882715@qq.com>;
主题: Khouloud Zemmeli answered you: A lot of errors in STM32Cube_FW_F0_V1.11.0
​Ok Thanks for the share, for the 3rd problem it's reproduced now, And it will be fixed too. Still the 1er error, need your ioc file , just copy the content of our ioc file as you have already did . Best Regards, Khouloud.
Khouloud Zemmeli (ST Employee)
Best Regards,
Khouloud.
View/Answer or reply to this email
Replying to
6738827151.541988037532413E12 (Community Member)
Wednesday, November 27, 2019 5:53 PM
Dear Khouloud Zemmeli,
Tian Naxin
I copy the content of our ioc file as below:
File.Version=6
Mcu.Family=STM32F0
Mcu.IP0=CRC
Mcu.IP1=NVIC
Mcu.IP2=RCC
Mcu.IP3=SYS
Mcu.IPNb=4
Mcu.Package=LQFP64
Mcu.PinsNb=2
Mcu.ThirdPartyNb=0
Mcu.UserConstants=
PCC.Checker=false
PCC.Line=STM32F0x2
PCC.Seq0=0
PCC.Series=STM32F0
PCC.Temperature=25
PCC.Vdd=3.6
RCC.FamilyName=M
board=custom
Thursday, November 28, 2019 12:32 AM
Best Regards,
Khouloud.
Thursday, November 28, 2019 1:37 AM
You're receiving emails when someone "Comments on my posts."
To change or turn off ST Community email, log in as 673882715@qq.com.st.
Are notifications about this post getting annoying? Reply to this email with the word " mute ".
STMicroelectronics N.V.
