Stm32 cube monitor show value zero
‎2023-10-29 5:29 AM - edited ‎2023-10-29 6:19 AM
I am using STM32H503RB nucleoboard. I have initialized project from cubeMX with default settings and only added a variable 'x' which is incremented with 100ms period. On CubeMonitor, 'x' variable value is always zero. When I debug I can see variable is incrementing. How can it be possible? By the way I am using windows 11.
By the way, I realized that if I work on STM32f4 discovery, everything is okay. It seems that stlink v3 may cause problem on stm32cube monitor. It is not related with windows 11 or 10
‎2023-10-30 1:07 AM
Hello
There are some points to check in the wiki help : STM32CubeMonitor:Troubleshooting - stm32mcu
For the STM32H503, the debug port is port 1. It is necessary to set the "Access point" to 1 in the "variables" node.
As usually the port 0 is used, it may be set to 0 in your flow and in this case the value returned is always 0. Can you check if you have the "access point" set to 1 ?
Please let us know if it helps. Thank you.
‎2023-10-30 1:07 AM
Hello
‎2023-10-31 1:10 AM
Thank you. It is working now.
