STM Cube Monitor settings.js flowFile does not work
2022-10-20 01:32 AM
in cube monitor settings.js file there is a line
//flowFile: 'flows.json',
As it is commented, the used flow file should fall back to a default.
But when uncommenting it and setting to a certain file name it does nor work, it still uses stm32cubemonitor/flows.json.
Is there any way to have several desktop links that each open cube monitor with a diferent flow file?
Reading the node red docs this should be possible, but it seems not with cube monitor
Any help is welcome
PS Which is the right group for cube monitor questions?
STM32CubeMonitor
2022-11-17 05:08 AM
Hi @Mr_M_from_G
You're right //flowFile is not used in STM32CubeMonitor. I'll raise a ticket to dev team in order to evaluate this request.
STM32CubeMonitor topic is the right group.
