2022-05-11 06:20 AM
In wiki i read about using "Single value" node for variables visualization in text frames like "Numeric" node and it working fine for it. But i cant to force to work it with "Chart" node. How it can be done?
2022-05-16 08:17 AM
Hello @EAlek.1
ST chart could not be used as output of single value. If you want to plot only one variable, you can add another variables/processing nodes to select corresponding variable.
2022-05-16 08:17 AM
Hello @EAlek.1
