Wrong address in debug mode.(STM32G431)
khong.1
Hi I am using STM32G431 and last version of CubeIDE.
When I am debugging on ADC12 Common resistor, It's address is 0x50000200.
The address should be 0x50000300.
How can I change that address?
Or Can you change it?
3 REPLIES 3
It's defined in stm32g431xx.h. Make sure you're including the right file. Appears to be correct:
#define ADC12_COMMON_BASE     (AHB2PERIPH_BASE + 0x08000300UL)
 https://github.com/STMicroelectronics/STM32CubeG4/blob/master/Drivers/CMSIS/Device/ST/STM32G4xx/Include/stm32g431xx.h
khong.1
Thank you for your answer. But I am talking about SVD File.
Anyway I found that file below link.
https://github.com/posborne/cmsis-svd/
and I changed the base address of ADC12_COMMON_BASE.
Now I can debug without problem. I think ST should change SVD file.
Hi @khong.1​ ,
Thanks for bringing the error to our attention. It is tracked internally.
-Amel
