Why cannot use the open project menu?
JohnsonWang
When I run STM32CubeIDE, the open project menu is disabled (in grey color). How can I active it?issue.jpg
Karl Yamashita
Principal
You need to highlight the unopened project in the project tree. Then you'll be able to open the project. If you want to work with an existing project that isn't in your project tree, then you need to import the project.
Don't worry, I won't byte.
TimerCallback tutorial! | UART and DMA Idle tutorial!
2 REPLIES 2
Karl Yamashita
Principal
JohnsonWang
Thank you so much! The issue has been fixed.
