2023-07-19 7:57 AM
The newest version of CubeIDE requires a sign-in to myST, but the dialog box hangs on Ubuntu. Pretty frustrating...
2023-07-26 8:43 AM
Hello @shane mattner ,
The issue is not reproduced from my side. Please, try to verify the network connection.
Thanks,
Rim
2023-11-10 6:28 AM
With CubeIDE version 1.13.2 on Windows I also am unable to sign-in. This started ~Nov 6, 2023. Prior to that, no problem.
2023-12-05 5:24 PM
This happened to me as well on Linux, after several retries it worked.
2023-12-07 11:10 PM
@shane mattner what is the version of your Ubuntu ? Does the bug still occur in 1.14.0 release ?
@quackquack what are your Linux distribution and version ?
2023-12-07 11:25 PM
CubeMX version 6.9.2, Linux Mint 20.3. I selected a new MCU and when I wanted to generate the code it presented a blank dialog box, presumably for downloading related files. Retrying a few times eventually showed a login form. The internet was working fine at the time.
2024-05-10 12:00 PM
I'm struggling to log in with the myST link as well - I have Version 1.15.0, on a Windows 10
2024-05-14 1:28 PM
I cannot login to my-ST as well, I get stuck on User Authentication Dialog forever, with the lines bumping as if it was loading.
I'm running version 1.15.1, on Ubuntu 24.04.
2024-05-15 9:45 PM
I'm actually trying to use it on a fresh windows 11 installation and can confirm the Piece of S**T doesn't work here either!
2024-05-16 3:37 AM
I've booted a new system, with Ubuntu 22.04, and tested Cube IDE version 1.15.1 and 1.14.0. It won't let me login anyway, so I guess they're having a server issue.
