Target unknown error 19
‎2024-04-26 4:14 AM
Error in initializing ST-LINK device.
Reason: Unknown. Please check power and cabling to target.
how to clear the above error, please reply immediately in urgent base to clear the above error
‎2024-04-26 4:48 AM
You need to give more context:
- What STM32CubeIDE version?
- What is your target?
- When, exactly, does this occur?
So did you do that?
@sreedharan1196 wrote:please reply immediately in urgent base to clear the above error
http://www.catb.org/~esr/faqs/smart-questions.html#urgent
‎2024-04-26 4:53 AM
- What STM32CubeIDE version? - 1.15.0
- What is your target? - stm32l051c8t7 - using stlink
- When, exactly, does this occur - after uploading the code
So did you do that? - yes done
‎2024-04-26 5:22 AM
More details needed: is that an ST board, or your own custom design.
you'll get better help more quickly by providing full details up-front - rather than having to pull them incrementally from you.
‎2024-04-26 5:40 AM
i am using customized board, we are using
‎2024-08-28 5:25 AM
This error could be caused by a misconfiguration of the communication pins between the STM and the ST-Link or because the microcontroller is in deep sleep mode.
- Check your .ioc file and go to System Core -> SYS -> Serial Wire.
- If these settings were disabled, it means the STM can't communicate with the ST-Link. Alternatively, the issue might be that the microcontroller was programmed to enter deep sleep mode.
- In both cases, the solution is the same: you need to connect through STM32CubeProgrammer. Set the connection mode to "Under Reset" and perform a "Full Chip Erase" to clear the flash memory.
After doing this, you should be able to program the STM without any issues.
If you still can't connect the device even after configuring it in "Under Reset" mode, the problem might be with the ST-Link itself—possibly because it's not an original one. Personally, I used a programmer from a Nucleo board, and that worked fine for me.
