STMCubeIDE v1.16.1 UI is Trimming Double Quotes when Adding Symbols to Project
‎2024-10-22 11:26 PM
Issue occurs in this build:
To reproduce:
- In an STM32MCU project right click properties
- Navigate to C/C++ General -> Paths And Symbols
- Select the Symbols Tab
- Add a new Symbol and in the value field, reference an environment variable inside quotes e.g. "${PATH}"
- Click save and the trailing double quote is removed
The workaround is to edit the symbols elsewhere see below noting where I added the extra quote:
‎2024-10-22 11:42 PM
Hello @davef and welcome to the ST Community.
I'm sending this for internal investigation, and I will be back to you as soon as I have a clear answer.
Best Regards.
STTwo-32
‎2024-10-23 3:30 PM
Thank you. Another thing I noticed is that system environment variables only seem to be refreshed on opening the workspace, is there a way to refresh the cached environment variables when running a pre compile action or script?
