JZaya.1
Jul 6, 2023 06:44 UTC
STM32CubeMX basics: 10.10 STM32Cube HAL labs UART - Lab UART IT
I am following tutorial and the file does not compile, what is wrong? https://www.youtube.com/watch?v=5i-Gw7OC7oo&list=PLnMKNibPkDnGtuIl5v0CvC81Am7SKpj02&index=48
/* USER CODE BEGIN PV */
uint8_t buffer_tx[10] = {10,11,12,13,14,15,16,17,18,19};
uint8_t buffer_rx[10];
/* USER CODE END PV */
/* USER CODE BEGIN 0 */
HAL_UART_Receive_IT(&huart1, buffer_rx, 10);
HAL_UART_Transmit_IT(&huart1, buffer_tx, 10);
/* USER CODE END 0 */
/* USER CODE BEGIN 4 */
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart){
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart){
while (1);
/* USER CODE END 4 */
../Core/Src/main.c:60:21: error: expected declaration specifiers or '...' before '&' token
60 | HAL_UART_Receive_IT(&huart1, buffer_rx, 10);
../Core/Src/main.c:60:30: error: expected declaration specifiers or '...' before 'buffer_rx'
../Core/Src/main.c:60:41: error: expected declaration specifiers or '...' before numeric constant
../Core/Src/main.c:61:22: error: expected declaration specifiers or '...' before '&' token
61 | HAL_UART_Transmit_IT(&huart1, buffer_tx, 10);
../Core/Src/main.c:61:31: error: expected declaration specifiers or '...' before 'buffer_tx'
../Core/Src/main.c:61:42: error: expected declaration specifiers or '...' before numeric constant
    Graduate II
    Jul 6, 2023 07:06 UTC
    Hello. Insert these lines:
    Inside of some function (main for example). Now these are treated as function prototypes since they seems to be missplaced.
    KDJEM.1
    Jul 6, 2023 07:27 UTC
    Hello @JZaya.1 ,
    I advise you to take a look at this wiki: Getting started with UART
    This article explains what is UART and how to use it through examples using  NUCLEO-L476RG boards
    • Simple UART communication in polling mode
    • UART with Interrupt
    • UART with DMA
    This wiki can help you to set up UART and generate code with STM32CubeIDE and to use HAL functions.
    Thank you.
    Kaouthar
