STM32CubeIDE Version: 1.15.0 Update and Login Problem
‎2024-03-26 9:12 AM
Hello 
The STM32CubeIDE Version: 1.15.0 doesn't create the code for me because I can't login in the software persistently can't connect to the internet. I followed some advice found on this community thread https://community.st.com/t5/stm32cubeide-mcus/myst-login-issue-in-stm32cubeide/td-p/575447 but to no avail. What can I do ?
ST boards
‎2024-04-03 10:31 AM
Hello
Im resolve this issue recovering Windows.
The problem are a bad setting of Windows Defender. In my case the firewall blocked the app in outgoing internet.
Thanks for intresting
‎2024-04-02 6:38 AM
Hello @AntoR
Could you share the .log and .ide.log file from the workspace/metadata folder.
Could you make the test with CubeMX as standalone application.
Did this behavior appeared with older CubeIDE versions?
BR,
Semer.
Hello
