STM32CubeIDE reduce categories table
HMSEdinburge
Hello... could anyone advise how to reduce the categories table on the left? i couldn't reduce it !  cos i couldn't see the pull-down menu "access only + MPU..." I m already using a 32" monitor! IDE.jpg
7 REPLIES 7
Souhaib MAZHOUD
Hello @HMSEdinburge
Actually, you can extend the Tab configuration to better display the parameter settings
Thx,
Souhaib
Yes, i already extended it to the end... only if you can advise how to reduce the categories menu.... mine is fixed dead unable to reduce it at all.
Are you using the last version of the CubeMX (V6.13.0). If no, please try using this version. From my side I can reduce the categories menu.
i m using STM32CubeIDE v1.15.1 no CubeMX...or how to check cubemx?
ok i see, i m using Cubemx 6.12.1.202409122..
how to upgrade to CubeMX (V6.13.0).
Hello
If you are using CubeMX standalone you can upgrade by clicking on Help>Check for update, then new STM32CubeMX Release as below:
The same way in STM32CubeIDE, you can find updates in Help > Check for updates.
Thx.
