2025-02-26 10:29 AM
after start STM32CubeIDE_1.17.0 the IDE crash after 10-20 seconds.
- Im try start with admins -> same
- remove workspace .metadata -> same
- set different java in to path -> same
- reinstall IDE new -> same
.ide.log in workspace folder
.ide.log
2025-02-26 19:08:45,884 [INFO] Activator:176 -
2025-02-26 19:08:45,885 [INFO] Activator:177 - !SESSION log4j initialized
2025-02-26 19:08:47,874 [INFO] LogOutputStream:77 - [STDOUT_REDIRECT]
2025-02-26 19:08:54,458 [INFO] ApplicationProperties:184 - Using Application install path: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809
2025-02-26 19:08:54,471 [INFO] DbMcusXml:78 - Set database path to: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809\\db\/mcu/
2025-02-26 19:08:54,471 [INFO] ApiDb:274 - Set plugin database path to: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809\\db\/plugins/boardmanager/
2025-02-26 19:08:54,471 [WARN] ApiDb:259 - Overriding images path with different value: => C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809\\db\/plugins/mcufinder/images/
2025-02-26 19:08:54,476 [INFO] ApiDb:250 - Set database path to: C:\Users\maria\.stmcufinder\plugins\mcufinder//mcu/
2025-02-26 19:08:54,477 [INFO] DbMcusAds:125 - Set database path to: C:\Users\maria\.stmcufinder\plugins\mcufinder//mcu/
2025-02-26 19:08:54,478 [INFO] CrossReferenceDbSqlite:203 - Set database path to: C:\Users\maria\.stmcufinder\plugins\mcufinder//mcu/cs/
2025-02-26 19:08:54,554 [INFO] RulesReader:64 - Compatibility file has been processed (297 Rules)
2025-02-26 19:08:54,618 [INFO] DbMcusXml:78 - Set database path to: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809\\db\/mcu/
2025-02-26 19:08:54,618 [INFO] ApiDb:274 - Set plugin database path to: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809\\db\/plugins/boardmanager/
2025-02-26 19:08:54,618 [INFO] ApiDb:261 - Set plugin images path to: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809\\db\/plugins/mcufinder/images/
2025-02-26 19:08:54,618 [WARN] DbFile:41 - Overriding database path with different value: C:\Users\maria\.stmcufinder\plugins\mcufinder/ => C:\Users\maria\.stmcufinder\plugins\mcufinder
2025-02-26 19:08:54,618 [INFO] ApiDb:250 - Set database path to: C:\Users\maria\.stmcufinder\plugins\mcufinder//mcu/
2025-02-26 19:08:54,618 [INFO] DbMcusAds:125 - Set database path to: C:\Users\maria\.stmcufinder\plugins\mcufinder//mcu/
2025-02-26 19:08:54,619 [WARN] DbFile:41 - Overriding database path with different value: C:\Users\maria\.stmcufinder\plugins\mcufinder/ => C:\Users\maria\.stmcufinder\plugins\mcufinder
2025-02-26 19:08:54,619 [INFO] CrossReferenceDbSqlite:203 - Set database path to: C:\Users\maria\.stmcufinder\plugins\mcufinder//mcu/cs/
2025-02-26 19:08:54,677 [INFO] MainPanel:272 - HeapMemory: 268435456
2025-02-26 19:08:54,735 [INFO] DbMcusXml:78 - Set database path to: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809\\db\/mcu/
2025-02-26 19:08:54,735 [INFO] ApiDb:274 - Set plugin database path to: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809\\db\/plugins/boardmanager/
2025-02-26 19:08:54,735 [INFO] ApiDb:261 - Set plugin images path to: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809\\db\/plugins/mcufinder/images/
2025-02-26 19:08:54,736 [WARN] DbFile:41 - Overriding database path with different value: C:\Users\maria\.stmcufinder\plugins\mcufinder/ => C:\Users\maria\.stmcufinder\plugins\mcufinder
2025-02-26 19:08:54,736 [INFO] ApiDb:250 - Set database path to: C:\Users\maria\.stmcufinder\plugins\mcufinder//mcu/
2025-02-26 19:08:54,736 [INFO] DbMcusAds:125 - Set database path to: C:\Users\maria\.stmcufinder\plugins\mcufinder//mcu/
2025-02-26 19:08:54,736 [INFO] CrossReferenceDbSqlite:203 - Set database path to: C:\Users\maria\.stmcufinder\plugins\mcufinder//mcu/cs/
2025-02-26 19:08:54,749 [INFO] ApplicationProperties:184 - Using Application install path: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809
2025-02-26 19:08:54,750 [INFO] PluginManage:196 - Search for loadable plugins [exclusion list=, ]
2025-02-26 19:08:54,751 [INFO] PluginManage:310 - Check plugin analytics
2025-02-26 19:08:59,791 [INFO] AnalyticsPlugin:253 - Accepted Software Licenses: STM32CubeMX.6.13.0
2025-02-26 19:08:59,792 [INFO] AnalyticsPlugin:255 - Accepted CMSIS Pack Licenses:
2025-02-26 19:08:59,792 [INFO] AnalyticsPlugin:257 - Accepted Firmware Licenses: FW.H7.1.11.0
2025-02-26 19:08:59,794 [INFO] PluginManage:359 - Loaded plugin analytics (category:tool,tabindex:-1)
2025-02-26 19:08:59,795 [INFO] PluginManage:310 - Check plugin cadmodel
2025-02-26 19:08:59,797 [INFO] CADModel:105 - Init CAD model plugin
2025-02-26 19:08:59,797 [INFO] PluginManage:359 - Loaded plugin cadmodel (category:power,tabindex:5)
2025-02-26 19:08:59,797 [INFO] PluginManage:310 - Check plugin clock
2025-02-26 19:08:59,803 [INFO] PluginManage:359 - Loaded plugin clock (category:base,tabindex:2)
2025-02-26 19:08:59,803 [INFO] PluginManage:310 - Check plugin ddr
2025-02-26 19:08:59,804 [INFO] PluginManage:359 - Loaded plugin ddr (category:tool,tabindex:6)
2025-02-26 19:08:59,805 [INFO] PluginManage:310 - Check plugin filemanager
2025-02-26 19:08:59,937 [INFO] PluginManage:359 - Loaded plugin filemanager (category:base,tabindex:10)
2025-02-26 19:08:59,937 [INFO] PluginManage:310 - Check plugin ipmanager
2025-02-26 19:08:59,957 [INFO] PluginManage:359 - Loaded plugin ipmanager (category:base,tabindex:5)
2025-02-26 19:08:59,957 [INFO] PluginManage:310 - Check plugin lpbam
2025-02-26 19:08:59,963 [INFO] PluginManage:359 - Loaded plugin lpbam (category:base,tabindex:0)
2025-02-26 19:08:59,963 [INFO] PluginManage:310 - Check plugin memorymap
2025-02-26 19:08:59,973 [INFO] PluginManage:359 - Loaded plugin memorymap (category:base,tabindex:4)
2025-02-26 19:08:59,973 [INFO] PluginManage:310 - Check plugin pinoutandconfiguration
2025-02-26 19:08:59,978 [INFO] PluginManage:359 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2025-02-26 19:08:59,979 [INFO] PluginManage:310 - Check plugin pinoutconfig
2025-02-26 19:09:00,040 [WARN] SupportedApi:132 - Cannot load RTOS API schema: s4s-elt-must-match.1: The content of 'definitions' must match (annotation?, (simpleType | complexType)?, (unique | key | keyref)*)). A problem was found starting at: attribute.
2025-02-26 19:09:00,119 [INFO] PluginManage:359 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2025-02-26 19:09:00,119 [INFO] PluginManage:310 - Check plugin power
2025-02-26 19:09:00,125 [INFO] PluginManage:359 - Loaded plugin power (category:power,tabindex:4)
2025-02-26 19:09:00,125 [INFO] PluginManage:310 - Check plugin projectmanager
2025-02-26 19:09:00,135 [INFO] PluginManage:359 - Loaded plugin projectmanager (category:projectmanager,tabindex:4)
2025-02-26 19:09:00,135 [INFO] PluginManage:310 - Check plugin rif
2025-02-26 19:09:00,138 [INFO] PluginManage:359 - Loaded plugin rif (category:base,tabindex:3)
2025-02-26 19:09:00,138 [INFO] PluginManage:310 - Check plugin thirdparty
2025-02-26 19:09:00,237 [INFO] PluginManage:359 - Loaded plugin thirdparty (category:base,tabindex:-1)
2025-02-26 19:09:00,237 [WARN] IntegrityCheckThread:84 - waiting for thirdparty lock release [integrity check]
2025-02-26 19:09:00,237 [INFO] PluginManage:310 - Check plugin tools
2025-02-26 19:09:00,237 [INFO] IntegrityCheckThread:86 - entering critical section [integrity check]
2025-02-26 19:09:00,238 [INFO] ThirdPartyUpdaterWithRetryManager:70 - Updater plugin not ready yet. [1/15]
2025-02-26 19:09:00,240 [INFO] PluginManage:359 - Loaded plugin tools (category:base,tabindex:7)
2025-02-26 19:09:00,241 [INFO] PluginManage:310 - Check plugin tutovideos
2025-02-26 19:09:00,374 [INFO] PluginManage:359 - Loaded plugin tutovideos (category:base,tabindex:-1)
2025-02-26 19:09:00,374 [INFO] PluginManage:310 - Check plugin updater
2025-02-26 19:09:00,390 [INFO] PluginManage:359 - Loaded plugin updater (category:base,tabindex:12)
2025-02-26 19:09:00,390 [INFO] PluginManage:310 - Check plugin userauth
2025-02-26 19:09:00,394 [INFO] UserAuth:118 - Init User Auth plugin
2025-02-26 19:09:00,395 [INFO] PluginManage:359 - Loaded plugin userauth (category:base,tabindex:14)
2025-02-26 19:09:00,396 [INFO] PluginManage:283 - PluginManage : Loaded plugins [18]
2025-02-26 19:09:00,546 [INFO] PinOutPanel:1589 - setPackage(No Configuration,No Configuration)
2025-02-26 19:09:00,613 [INFO] CADModel:165 - CPN selected for project level
2025-02-26 19:09:00,613 [INFO] CADModel:114 - Register for checkConnection events
2025-02-26 19:09:00,632 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,633 [INFO] PluginManager:220 - loadIPPluginJar : add adc
2025-02-26 19:09:00,635 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,635 [INFO] PluginManager:220 - loadIPPluginJar : add aes
2025-02-26 19:09:00,638 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,638 [INFO] PluginManager:220 - loadIPPluginJar : add can
2025-02-26 19:09:00,639 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,639 [INFO] PluginManager:220 - loadIPPluginJar : add comp
2025-02-26 19:09:00,641 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,642 [INFO] PluginManager:220 - loadIPPluginJar : add cryp
2025-02-26 19:09:00,644 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,644 [INFO] PluginManager:220 - loadIPPluginJar : add ddr_ctrl_phy
2025-02-26 19:09:00,646 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,646 [INFO] PluginManager:220 - loadIPPluginJar : add dfsdm
2025-02-26 19:09:00,650 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,650 [INFO] PluginManager:220 - loadIPPluginJar : add dma
2025-02-26 19:09:00,652 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,652 [INFO] PluginManager:220 - loadIPPluginJar : add dma3
2025-02-26 19:09:00,656 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,656 [INFO] PluginManager:220 - loadIPPluginJar : add extmemmanager
2025-02-26 19:09:00,657 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,657 [INFO] PluginManager:220 - loadIPPluginJar : add fatfs
2025-02-26 19:09:00,659 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,660 [INFO] PluginManager:220 - loadIPPluginJar : add fmc
2025-02-26 19:09:00,664 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,664 [INFO] PluginManager:220 - loadIPPluginJar : add freertos
2025-02-26 19:09:00,665 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,665 [INFO] PluginManager:220 - loadIPPluginJar : add genericplugin
2025-02-26 19:09:00,668 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,668 [INFO] PluginManager:220 - loadIPPluginJar : add gfxmmu
2025-02-26 19:09:00,671 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,671 [INFO] PluginManager:220 - loadIPPluginJar : add gic
2025-02-26 19:09:00,674 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,674 [INFO] PluginManager:220 - loadIPPluginJar : add gpio
2025-02-26 19:09:00,675 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,675 [INFO] PluginManager:220 - loadIPPluginJar : add gtzc
2025-02-26 19:09:00,677 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,677 [INFO] PluginManager:220 - loadIPPluginJar : add hash
2025-02-26 19:09:00,678 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,678 [INFO] PluginManager:220 - loadIPPluginJar : add i2c
2025-02-26 19:09:00,680 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,680 [INFO] PluginManager:220 - loadIPPluginJar : add i2s
2025-02-26 19:09:00,682 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,682 [INFO] PluginManager:220 - loadIPPluginJar : add i3c
2025-02-26 19:09:00,684 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,684 [INFO] PluginManager:220 - loadIPPluginJar : add ipddr
2025-02-26 19:09:00,688 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,688 [INFO] PluginManager:220 - loadIPPluginJar : add linkedlist
2025-02-26 19:09:00,691 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,691 [INFO] PluginManager:220 - loadIPPluginJar : add lorawan
2025-02-26 19:09:00,692 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,692 [INFO] PluginManager:220 - loadIPPluginJar : add ltdc
2025-02-26 19:09:00,695 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,696 [INFO] PluginManager:220 - loadIPPluginJar : add mdma
2025-02-26 19:09:00,698 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,698 [INFO] PluginManager:220 - loadIPPluginJar : add nvic
2025-02-26 19:09:00,700 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,700 [INFO] PluginManager:220 - loadIPPluginJar : add opamp
2025-02-26 19:09:00,702 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,702 [INFO] PluginManager:220 - loadIPPluginJar : add openamp
2025-02-26 19:09:00,704 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,704 [INFO] PluginManager:220 - loadIPPluginJar : add pdm2pcm
2025-02-26 19:09:00,708 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,710 [INFO] PluginManager:220 - loadIPPluginJar : add plateformsettings
2025-02-26 19:09:00,711 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,711 [INFO] PluginManager:220 - loadIPPluginJar : add quadspi
2025-02-26 19:09:00,713 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,714 [INFO] PluginManager:220 - loadIPPluginJar : add radio
2025-02-26 19:09:00,717 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,717 [INFO] PluginManager:220 - loadIPPluginJar : add resmgrutility
2025-02-26 19:09:00,718 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,718 [INFO] PluginManager:220 - loadIPPluginJar : add sai
2025-02-26 19:09:00,720 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,720 [INFO] PluginManager:220 - loadIPPluginJar : add spi
2025-02-26 19:09:00,723 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,725 [INFO] PluginManager:220 - loadIPPluginJar : add stm32_wpan
2025-02-26 19:09:00,725 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,725 [INFO] PluginManager:220 - loadIPPluginJar : add tim
2025-02-26 19:09:00,727 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,727 [INFO] PluginManager:220 - loadIPPluginJar : add touchsensing
2025-02-26 19:09:00,728 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,729 [INFO] PluginManager:220 - loadIPPluginJar : add tracer_emb
2025-02-26 19:09:00,731 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,731 [INFO] PluginManager:220 - loadIPPluginJar : add ts
2025-02-26 19:09:00,732 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,732 [INFO] PluginManager:220 - loadIPPluginJar : add tsc
2025-02-26 19:09:00,733 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,733 [INFO] PluginManager:220 - loadIPPluginJar : add ucpd
2025-02-26 19:09:00,735 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,735 [INFO] PluginManager:220 - loadIPPluginJar : add usart
2025-02-26 19:09:00,737 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-02-26 19:09:00,737 [INFO] PluginManager:220 - loadIPPluginJar : add usbx
2025-02-26 19:09:00,851 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:00,870 [INFO] RulesReader:64 - Compatibility file has been processed (297 Rules)
2025-02-26 19:09:00,878 [INFO] RulesReader:64 - Compatibility file has been processed (297 Rules)
2025-02-26 19:09:00,885 [INFO] CADModel:165 - CPN selected for project level
2025-02-26 19:09:00,885 [INFO] CADModel:114 - Register for checkConnection events
2025-02-26 19:09:00,885 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:00,885 [ERROR] CADModel:125 - Updater not yet initialized, retry later
2025-02-26 19:09:00,983 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:00,983 [INFO] CADModel:165 - CPN selected for project level
2025-02-26 19:09:00,984 [INFO] CADModel:114 - Register for checkConnection events
2025-02-26 19:09:00,984 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:00,984 [ERROR] CADModel:125 - Updater not yet initialized, retry later
2025-02-26 19:09:00,986 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:01,057 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:01,061 [INFO] DbMcusAds:53 - JSON generation date=Tue Dec 17 17:01:15 CET 2024 (1734451275111)
2025-02-26 19:09:01,061 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:01,088 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2025-02-26 19:09:01,270 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:01,271 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:01,272 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:01,272 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2025-02-26 19:09:01,273 [FATAL] Updater:351 - Updater called before beeing initialized
2025-02-26 19:09:01,303 [ERROR] Updater:1198 - MainUpdater not yet initialized. External WinMGr cannot be set.
2025-02-26 19:09:01,304 [INFO] Updater:1134 - Updater Version found : 6.13.0
2025-02-26 19:09:01,315 [INFO] ApplicationProperties:184 - Using Application install path: C:\ST\STM32CubeIDE_1.17.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.13.0.202411220809
2025-02-26 19:09:01,323 [INFO] MainUpdater:5295 - Software Update Detected: STM32CubeMX
2025-02-26 19:09:02,836 [INFO] UpgradeLauncher:84 - Launching upgrade utility for software upgrade type: (MX) upgradeMode ( Rel)
2025-02-26 19:09:02,851 [INFO] UpgradeLauncher:93 - Upgrade utility launched for software upgrade
some one a idea ?
Marian
2025-02-27 3:59 AM
Maybe you should add info:
- on what system ?
- have/had older IDE version running?
- firewall/anti-virus disabled ?
2025-02-27 7:25 AM
Hi AScha.3
- Windows 11
- I have already older version on this maschine long time ago
- Im try and disconnect ethernet -> same, after 15sec "crash" / more precise CLOSE ! (not sure if crash !)
- java version
java 23.0.2 2025-01-21
Java(TM) SE Runtime Environment (build 23.0.2+7-58)
- change workspace -> same
2025-02-27 8:48 AM
update.
I make video from close session: problem in checking files for upgrade ...
Im install again new and start with admin -> same
what is here solotion ?
2025-02-27 10:04 AM
i just remember: on my Laptop (W10 or 11) similar problem: small splash screen coming, after some seconds away (crash or close), then coming up again...endless loop. (tried update Java, but same; tried older IDE version, same.)
On my Laptop (W11 professional, company version) from work/company, splash screen start and then working fine, no problem at all.
And on my PC, MxLinux , after some problems with a missing (old) lib, working fine. IDE 1.17.0
Just guessing: maybe some Win version have a problem - but i dont know why.
