STM32CubeIDE 1.10.1 compiles files twice
NFind.1634
I noticed a problem with STM32CubeIDE 1.10.1:
When build, a second time, the same files as before get compiled again.
All my projects were migrated from 1.9.
Steps to reproduce:
  1. Modify a file
  2. Run the build, it compiles that file
  3. Run the build, it compiles that file again
  4. Run the build, it finally does not compile that file
Thank you
Pavel A.
Evangelist III
This is a known issue with Eclipse CDT. Sometimes it does repro, sometimes not.
Try to clean & refresh& complete rebuild. Try to change the builder from external to internal or v.v.
EEbyKarl
I am using 1.10.1 and I can't duplicate your issue. For my project, it builds once and any subsequent builds afterwards do not rebuild the files until code is modified.
Pavel A.
Evangelist III
