2024-01-02 2:27 AM
Hi people...I couldn't able to get live expressions on debug can anyone help me to find a solution
2024-01-02 2:37 AM
Hello @SRAM.11 ,
First let me thank you for posting and welcome to ST Community.
I suggest that you Select the menu command [Window]>[Show View]>[Others] and tap [Live Expression] or use the [Quick Access] field and search for “Live Expression” and select it from the views.
Thanks.
Mahmoud.
2024-01-02 2:34 AM - edited 2024-01-02 2:39 AM
did you enable it, in debug configuration ? ->
Have you selected (while in debug session) in menu: window-> show view -> live expressions ?
2024-01-02 2:37 AM
Hello @SRAM.11 ,
Thanks.
Mahmoud.
2024-01-02 2:58 AM
thank you so much....i updated my workspace so i missed .Thank you
