2024-02-07 08:22 AM
I can't update my ST-Link V2
When i try to update first it says update error after that update succesfully.
2024-02-08 04:54 AM
2024-02-07 09:33 AM
What OS? You're already at the current version.
In Win7 there can be quite a significantly lag between "Open in update mode" and the drivers being installed properly for the different device it presents.
Potentially other issue is apps, like Keil etc, have a currently open context with the ST-LINK.
Serial# doesn't look obviously fake
2024-02-08 04:54 AM
I fix it thanks for reply.
I fix with hex folder.
