‎2020-08-26 6:32 PM
MCU Support,
I update to 1.4.2 and get a ST remind. See appendix. If I select cancel the update is terminated. Which options should I select? It confuses me because why STM reminds this if it is its software. Does other software come in?
Best regards,
Adam
‎2020-08-26 9:01 PM
Yep, it's unsigned. If you want to install it, click install anyway. It's not like ST created the entire IDE. They just took the existing Eclipse framework. I'm sure this warning comes from that framework, and ST's inability to get their own update signed, which is unfortunate.
‎2020-08-26 9:01 PM
‎2020-08-27 12:24 PM
Thank you TDK
