2025-03-03 1:05 PM
IDE VERSION: v1.14.1+
Target: STM32H750
Debugger: ST-Link
So, 98.9% of the time I try to enable RTOS aware while debugging using the ST-Link I receive this message:
After that, I'm no longer able to debug code. This is normally "worked around" by closing the IDE and trying again, but as you can imagine, it is not a viable solution.
I have no clue what is going on, so if you need details, please share what you might need captured.
2025-03-03 1:19 PM
I should also add that this is for FreeRTOS.
