"Create minimal project failure: cannot read template source" error
EKupe.1
Every time i'm trying to open a new project in IDE, after choosing the board and a name for the project i get this "Create minimal project failure: cannot read template source" error message
Is there any solution?
screenshot is attached
Thanks in advance,
Ehud
Pavel A.
Evangelist III
You have a space in your Windows username: ehud%20kuper.
-- pa
5 REPLIES 5
Hi @EKupe.1​
Which STM32CubeIDE version do you use?
Best regards,
Nesrine
EKupe.1
the one that available at the site (1.3.0)
also i had checked for upgrades so now its 1.3.1
Pavel A.
Evangelist III
-- pa
Hi @EKupe.1​
Try to change the space that's in your user name then tell me if it solve the issue.
Best regards,
Nesrine
Yep! It did solve the problem..thank you all very much!
I attach a youtube video that helped me change the user name (wasnt sure it would worked just with changing the folder name)
https://youtu.be/e7UnqBQLSAI
Thanks a lot!
Ehud
