Problem with nearly new Nucleo F722ZE
TLanc.1638
New Nucleo-F722ZE initially worked fine (initially prompted for software update). But after approx 3 hours when trying to Run->Debug , it now shows:
Waiting for debugger connection...
Debugger connected
Debugger connection lost.
Shutting down...
Power cycling everything doesn't help. Tried re-installing the latest ST-LINK software, still no change.
Nucleo-F429ZI, works ok on same computer and USB port.
Is the Nucleo faulty, or is there something else I can try?
Using a DELL?
Watch for Diagnostic Agent or Intel performance drivers in the mass-storage stack.
Check for screen saver or hard-drive power down on the PC.
If your code puts the device into low-power mode, ie WFI or SLEEP, it powers off the debug interface.
Watch also for disabling or interference with the debug pins.
