Problem with HRTIM with Nucleo-H743ZI2 Board
‎2020-05-20 4:31 AM
Hello Everybody
I have the Problem with my Hightimer PWM Output.
If I define that my HRTIM is working with 480MHz (CPU_Ck).
it will not and work with the normal 240MHz Output.
Why is that so?
- Labels:
HRTIM
STM32CubeIDE
STM32H7 series
TIM
‎2020-05-20 5:46 AM
Are you trying to get a PWM signal at 240MHz? That's above the max frequency of the GPIO pins.
‎2020-05-20 7:07 AM
‎2020-05-20 7:07 AM
‎2020-05-20 7:07 AM
‎2020-05-20 8:01 AM
‎2020-05-20 8:06 AM
Thanks for the answer
No sorry i have made a mistake while i was uploading the pictures
I try to get a faster 10 Bit PWM signal, because of that i need the high resolution timer with 480MHz instead of 240MHz.
