Problem occured on debugger : Error message from debugger back end: /usr/bin/arm-none-eabi-gdb: Error in sourced command file
ASEGU.1
i work on Archlinux, and i recently installed STM32CubeIDE. I previously had some issues with arm-none-eabi-gdb, which couldn't check the version because of the missing library libncurses5 (which was on version 6 on my computer). So i downloaded ncurses5-compat-libs and the previous error was cleaned.
So now, this is this one coming in and i have no clue of how i could patch it.
It seems to come from the package arm-none-eabi-gdb code, but i can't believe an official used this much package has errors.
Any ideas of where it could come from ?
Thanks a lot !
0 REPLIES 0
